Mr.CRC
Hi:
I have been using MOSFET drivers to pulse LEDs at currents of up to 21A
(for 100s of ns to several microsecond pulses) and down to about 22ns
for 1A pulses into 1mm^2 power LEDs.
I can't get any faster with the drivers I've tried than about 20ns for
"parity" optical output power with the 1.0A CW max current typical of
blue 1mm^2 LEDs. (see note 1 below)
I wish to achieve 10-20ns pulses of 1-10 amps.
Three circuits that come to mind are:
1. Capacitive discharge by MOSFET switch such as the Directed Energy
PCO-7110 driver.
This circuit has the drawback of a slow trailing edge.
2. Discontinuous current mode flyback circuit. The stored current in
the inductor is switched into the LED when the MOSFET turns off.
This circuit also has a slower tail than a symmetric drive, but is
better than RC. I have gotten 30ns or so 3-4A pulses in a LTspice sim,
with 100-1000pF in parallel with diode loads.
3. Continuous current mode flyback circuit. The stored current in the
inductor is switched into the LED when the MOSFET turns off, then
shunted back through the FET when it turns back on.
This circuit produces a nice sharp pulse. I have gotten 15ns or so 3-4A
pulses in a LTspice sim, with 100-1000pF in parallel with diode loads.
At this point I have no idea if the simulated performance can be
realized with a physical circuit.
Also, much of the challenge is in the MOSFET gate drive. Hence, I keep
coming back to the fact that if the gate driver is fast enough, just
hook the LED to it and be done!
I did buy some Directed Energy (IXYS) laser diode driver assemblies to
test, but haven't gotten to spend much time with them. I still want to
be able to build my own, to meet custom mechanical requirements.
Just wondering if there are any completely different approaches to think
about?
I'm aware of transmission line pulse generation approaches, and would
consider them. But that should be a last resort. Those still require a
fast switch. So it seems all of this boils down to "how to switch
on/off several amps in 5ns or less?"
NOTES:
1. So far I've tried TC4422A and IXD630. The IXD630 is better on
paper, but with real LEDs, the TC4422A outperforms in the <100ns regime.
The way to get it to work isn't very practical for anything but lab
experimentation anyway, since to get very short pulses, I have to just
"tickle" the switching threshold of the driver by varying the amplitude
of the input pulse. The actual input pulse duration hardly even matters
below about 60ns, so I set it to 40ns and then the output pulse width
becomes a function of the input amplitude. This also varies with supply
voltage, and horribly with temperature.
PCO-7110 driver.
about?
NOTES:
