I have a shunt ammeter that has about 0.3 ohms of resistance and is made up internally with an electromagnet (a metal post with wire wound around the post and both ends of the wire connected to external terminals). The needle sits in the middle and fully deflects in either direction for about 2A of current depending on the direction of current flow.
I want to convert it to a voltmeter with an 8 to 16V range. A 12V stable reference power supply came to mind using a SEPIC DC-DC converter powered by the same battery whose voltage I am measuring. The SEPIC supply is connected to one side of the ammeter and a current limiting resistor and the battery is connected to the other side.
When the battery voltage is +/-4V different than the 12V reference and with 2 ohms of circuit resistance, 2A would be flowing and the ammeter would be fully deflected in one direction or the other. Current and subsequent ammeter deflection would be linear for < +/-4V.
Problem here is that a SEPIC converter can't sink current. I could add a current sink transistor switch and resistor possibly that turns on only when 12V < battery voltage.
4 switch Synchronous DC-DC converters can sink current, but this solution is expensive and i'm trying to find the lowest cost solution.
What do you guys recommend? I thought of using a Power Op Amp, but I think it would require a V+ and V- power input. I'm a bit rusty on Op Amps so I can use some help though.
