Hi everyone,
I am new to electronics and have little experience. I am working on a prototype and need some advice from you experts. I am needing to incorporate into my circuit an element that controls the current flow in real time. To be more specific, I have a device running with 2 sources in parallel; one source is variable and the other can be constant. Ideally, what I would like is to dial in a desired current into such a circuit element which I would need to constantly flow throughout. So if the variable source dissipates, the element will allow more current to be drawn from the more constant, reliable source to compensate and make that current whole again. What is such an element called, is it easy to buy, how expensive approximately, and do you recommend where I can buy one?
This is all DC btw.
Thank you so much in advance!
This is all DC btw.
