Ace
Have a spa protected by a 30 Amp, 230 V, GFCI breaker which I'm pretty sure
was bad,
so I replaced it.
Question(s):
Tested old one with ohm meter which shows open. Am I getting a good test?
(Literature with new one says both sides must be energized for GFCI to work)
If not a good test, how can I check old one?
Also, is above described breaker available in "designed for switching"?
Given the cost of this breaker, I was wondering how many duty cycles they
are
designed to handle when used as a switch. The recommendation is to check
them
every thirty days.
In other words, since the old breaker probably had no more than one hundred
(100)
on/off cycles over a span of six (6) years, why did it fail?
Thanks in advance.
was bad,
so I replaced it.
Question(s):
are
them
every thirty days.
(100)
Thanks in advance.
