Hi all,
I recently thought of an idea for a bullet chronograph and Power distribution estimator.
There is a group of peole out there who target shoot and hand load, who need to know the velocity of the bullets.
The chronographs I've seen used don't allow for in-situ data between material like wood boards and ballistics gel.
I propose:
A copper trace that is one wire, snaked across a film covering a lot of surface area. This is what the bullet breaks to initiate a detection.
The trace together with a resistor in series, forms a resistor in a Wheat Stone bridge.
When the trace is intack, there's 0 V at the bridge output.
When the trace is broken, there's a fraction of Vcc at the output.
The outputs go to an OP-AMP with gain of 10.
There's undoubtably instability in the bridge, hopefully on the order of 0.1V or lower, after balancing it with a linear pot and using 2% resistors.
An output of 0.1 gets up to 1 V with gain of 10 but with a broken trace, the bridge output is say 10 V, then 10 * 10 gets me up to the rail.
I still get garbage but I filter it later in MATLAB and with some analog filters.
Two or more such configurations are set up serially in the path of the bullet.
Each OP-AMP alternates from non-inverting to inverting configuration.
Each of these networks also has an anti aliasing filter.
The ouputs are connected in parallel to old computer sound card sampling at 48 kHz. This gives a sample window of ~21 us. For a bullet travelling at 1145 fps or 350 m/s, on the cm scale, that's a period of 28.6 us per cm.
I think the quantizing error sucks though.
I then use MATLAB to further filter the data and pick out the peaks in the signal. SInce I know the sample rate, I know the time between pulses and I know the distance.
Of course a better system would use a National Instruments data aquisition card. Then I get into more trouble with software and the like however.
Does anyone see a major flaw or unrealistic design expectation here?
I need to work out the sample related error for sure. I think the electronics are simple enough.
thanks !
wbg
I propose:
thanks !
wbg
