Roger Bourne
Hello all,
I want to implement a chopper amplifier (differential input, single
output) into a follower topology. Since a chopper amplifier works by
square wave modulating the input (chopping, originally by a mechanical
switch), amplifying the resultant AC signal,
and then synchronously detecting the amplified signal.... (copied this
bit from another post), is a follower topology (minus input shorted
with output) feasible with a chopper amplifier, or will the feedback
destroy basic chopper amplifier principle?
In other words, can a chopper amplifier be operated only in "open-
loop" mode (no feedback), or can the chopper amplifier replace op-amps
in typical op-amp topologies, meaning that it can handle feedback.
I am using the chopper amplifier to remove a signal's flicker noise.
This is why I am employing the chopper amplifier in a follower
topology.
Any help will be appreciated.
Regards,
-Roger
topology.
Regards,
-Roger
