I am wrapping up a few things for my LED project. I have 14 LED arrays. Each have 32 LEDs in series of 4 running @ 58mA. I am trying to figure out the correct wire gauge to use. So each array is drawing 464mA or .464A max for signal/brake intensity.
Each array is triggered by a power supply which is either triggered by a dual intensity PWM for driving or by a soon to be designed microprocessor for some special effects (sequential, etc). The wiring in question is ran from the power supply (Sharp 12v regs with a transistor doing on/off switching on pin 4 of the reg) to each individual 32 LED array. The power supply will also be fused for the max output of the entire power supply.
Circuit Schematic: (Note arrays are different than on schematic)
Uploaded with ImageShack.us
I have found several links with tables for this purpose but I would like to be absolutely certain.
Going by this I am assuming 30 AWG would be sufficient. Correct? No? I was under the impression wire length was taken into account for this as well?
I initially wanted to use ethernet cable to keep it all neat since i had plenty of connector from outdated laptops. Until I looked up ethernet specs and from I could find maxed out at about 350mA. Ethernet cable is 24 AWG IIRC so, why the low current rating? I guess that may be another question entirely but if I can use that it would be great.
If you need more info about specs of the project I will be more than happy to provide what I can! I appreciate your input!
