CSB
I'm beginning in electronics and have been trying projects that almost
all required different voltages, so I thought I'd build a PowerSupply unit
from scratch, instead of using batteries. So here's what the rectifier
part might look like:
_____________
| rect. | |
(CT) | |+ | ? µF
_|_ _|_ _|_
(assuming that running a few v-regs in parallel works?)
What kind of caps should I use for c1 and c2? Or is there a formula to
find the values? And is there anything else I should add in that part
(reverse-biased diodes to ground for each side, &c.)?
Any information/source of info is very welcome.
Thanks,
CSB
_____________
+9VAC | bridge | |--------| ~ + |----------------x--------> To 78xx v-regs
| rect. | |
-9VAC ----------- | |--------| ~ - |---x----------- | -------> To 79xx v-regs
0VAC | --- C1 --- C2-------| --- ? µF ---
(CT) | |+ | ? µF
_|_ _|_ _|_
Thanks,
CSB
