Choice of tape for LCD repair (EMI/RF tape?)
NoSp
I'm repairing an LCD display and metallic tape is used in several
places, as shown in these photos marked "sticky foil":
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
There are several types of "metallic tape" or "aluminum tape" in the
market, but I'm not sure what kind of characteristics I'm looking for,
and I really don't know what the LCD display needs it for anyway
-reducing electromagnetic and radio interference and taking away heat?
I first thought the tape should be electrical conductive, but using a
continuity testing function in a multimeter this seems not to be the
case. So what am I looking for?
Will this do?:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110254391809
NoSp
JANA said:
When servicing LCD screens and not replacing this tape, I found that at
times there were interference problems. This is why the manufactures
went to the extra expense to use this type of tape.
What kind of intereference?
Problems with wireless networking on a laptop?
I was under the impression that the tape was used to prevent the LCD
from overheating as well, but leaving it out won't cause any actual
physical damage then?
bz
You might cause interference with nearby shortwave radio equipment and even
with police and fire department or aircraft navigation equipment.
You need to be cautious about removing anything related to reducing Radio
Frequency Interference.
You could probably stick down some aluminum foil using double-stick clear
tape. Put a layer of clear tape on top if you want to insulate it as the
original apparently was.
You might be right. I wouldn't have guessed that but it may have some such
effect.
I would not leave it out. I would replace it with something as close as
possible to the original.
bz
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
NoSp
Jerry said:
You can
also go to a hardware store and buy metal tape, but it must be surface
insulated for safety issues.
I've just purchased a roll of "aluminum tape" at a local hardware store.
Didn't cost much. They had a multimeter at the store and I got to check
that the outer surface is conductive while the inner surface (the sticky
side) doesn't conduct electricity.
Its acrylic glue surface is protected against moisture, UV, heat and
aging and can stand temperatures up to 120 degrees C for short periods
of time.
The store had no idea if it could be used for shielding electronics (I
don't even know if they understood what I meant).
Does that sound like something I can use, or do I need to look for
something which is specifically named "shielding tape" or similar?
James Sweet
of time.
That stuff should be fine, give it a go.
