I have a number of 3.7V BRC 18650 Li ion batteries from Ultrafire, rated at 4200mAh - which I don't believe. So I have one of those natty little devices which can check this. I just put the batteries under load, and measure just about everything under the Sun - volts, amps watts, power etc. The only question is: what does the rating mean or claim? After discharge to zero volts (impossible)? Discharge to 50% of the volts? 75%?
Also, at what current should I discharge? 10% of the rating, ie 420mA?
Thanks for your help.
