Cheap solution for environmental chamber
David Novak
I need to test a product at hot and cold temperatures. Can anyone
suggest a cheap alternative to an environmental chamber?
A small freezer would probably be fine for the cold, but what is a good
solution for hot (50C)? I think a toaster oven would be too hot.
Thanks,
David
David Novak
Dajac Inc.
17152 Shadoan Way
Westfield, IN 46074
Email: [email protected]
Phone: 317-258-0223
Fax: 317-867-1888
www.dajac.com
Hardware/Software Consulting
Headlamp Alignment Equipment
K
krw
Phoenix, about this time of year.
Tim Wescott
Thanks,
David
A toaster oven and a (big) lamp dimmer. You'd have to monitor the
temperature yourself, or make a controller, but it'd do the job.
Or a toaster oven, a relay, a temperature controller from Omega, and a
temperature probe from same. "Cheap" may fall by the wayside without some
inspired eBay buying, but it'd also do the job.
Tim Wescott
Control systems and communications consulting
http://www.wescottdesign.com
Need to learn how to apply control theory in your embedded system?
"Applied Control Theory for Embedded Systems" by Tim Wescott
Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
E
Ecnerwal
Small freezer = insulated box.
Unplug freezer, run flat power cable inside with small thermostatically
controlled heater (PTC ceramic disk heaters (with fan) are reasonably
safe). Set for 50C. Light bulbs and a separate thermostat is another
classic heating method. Plain old resistive elements...hot is pretty
easy.
The freezer plastic interior might object, but if it's only 50C will
probably be fine. However, a few sheets of rigid board insulation (the
foil-faced stuff works particularly well) from the building supply and a
bit of tape (foil if you get the foil-faced board) could make you a
dedicated hot box easily enough - heat the same way, be able to run a
batch in hot and a batch in cold at the same time.
Tim Wescott
Control systems and communications consultinghttp://www.wescottdesign.com
Elsevier/Newnes,http://www.wescottdesign.com/actfes/actfes.html
Small chambers go for around $200 in the surplus shops, provided they
are the liquid nitrogen type. Full refrigeration costs considerably
more.
D from BC
Thanks,
David
David Novak
Dajac Inc.
17152 Shadoan Way
Westfield, IN 46074
Phone: 317-258-0223
Fax: 317-867-1888
www.dajac.com
Maybe try:
http://www.homedepot.com/webapp/wcs...d=10053&productId=100498583&categoryID=500500
$24.00 at Home Depot
Or ...
I do environmental tests in my kitchen oven. I haven't tried 50C but
my kitchen oven dial has 65C as a min.
I use a fan in the oven to circulate the air.
D from BC
Ben Jackson
If it's really small (eg single pcb) you could get one of those 6-pack
12V mini fridges. They use a peltier device and usually have a switch
to choose warming or cooling.
Rich Grise
Find a toaster oven that has a thermostat?
Good Luck!
Rich
Rich Grise
On Wed, 27 Jun 2007 09:46:21 -0400, David Novak
Maybe try:
Or ...
You idiot! That's a space heater for heaven's sakes - he doesn't want to
raise the whole blinkin' ROOM to 50C!
Try one of these:
http://www.homedepot.com/webapp/wcs...langId=-1&catalogId=10053&productId=100431020
Cheers!
Rich
RST Engineering \(jw\)
Down to WallyMart to get a moderatly large (compared with the DUT) camping
cooler. Drill a hole in the side for a thermometer probe (tight fit).
Light bulb and fan for heating. Remove light bulb. Insert dry ice for
chilling. Use a Polish temperature controller (light bulb and switch on the
fan) to regulate (sort of) temperature.
Jim
"Life is not a journey to the grave with the intention of arriving safely in
a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, with chocolate in one hand and wine in
the other, loudly proclaiming 'WOO HOO What a Ride!'"
--Unknown
martin griffith
Thanks,
David
David Novak
Dajac Inc.
17152 Shadoan Way
Westfield, IN 46074
Phone: 317-258-0223
Fax: 317-867-1888
www.dajac.com
If you have compressed air available, you could use a vortex cooler,
see wikidpedia
martin
D from BC
Try one of these:
Cheers!
Rich
Could still work.. I don't think the size of that environmental
chamber was mentioned yet.. :p
Heck...the OP might be able to insulate a closet and use that as an
environmental chamber..
Home Depot has pink foam insulation too.
I've turned washrooms into paint bake rooms :)
D from BC
Spurious Response
I'll bet the old lady just loved that little stunt.
Did you at least morph it into a grow room?
Carl Ijames
My full size gas oven is about 45C when set to the lowest "warm"
setting - try your oven at home.
Rich Grise
I have a "counter-top" oven that looks a lot like this one, except it's
white enamel:
http://homecooking.about.com/od/kitchenequipmentreviews/gr/nesco.htm
and I don't remember where I bought it or what brand it is, but it's got
a mechanical thermostat; the lowest indication is 150F, the highest is
400 or 450F, and at ambient I can hear (and feel) the knob thermostat
click about half-way up from "off" to "150", so it could probably be set
as low as 100F, if you have a decent thermometer and time to let it
stabilize. It's yours for the cost of shipping - make an email by
concatenating my first and last name and sending it to yahoo, if you're
interested.
http://mysite.verizon.net/richgrise/images/RoasterOven.jpg
CAUTION! 463KB picture file!
Cheers!
Rich
email: richgrise at ya-you-know-what-hoo etc. ;-)
MooseFET
You can buy http://www.digikey.com/scripts/dksearch/dksus.dll?Detail?Ref=537548&Row=155665&Site=US
and a relay to turn on and off a heater AKA big fat resistor or light
bulb.
If you put a lot of thermal mass inside the box, the thermostat won't
have to cycle very often. You can also size the heater so that it
isn't too strong.
Barry Lennox
Depends on how big your DUT is.
There was one in "Circuit Cellar" perhaps 3-4 years back. It used a
small "auto" fridge with Peltier effect coolers and a couple of WW
resistors for a heater, together with a small controller. These
fridges are the size that neatly holds a 6-pack.
I can find the reference to the exact issue if that helps.
Barry
Jasen
clothes dryer?
refrigerator shell with a heater and a thermostat installed.
Bye.
Jasen
