cheap mains stepdown 240-120
I have a simple but specific question.
Living in the UK, mains voltage is 240
I have several USA imported items that run on 120v and currently swap my external stepdown converter between them.
presuming the linear tx supplies inside the equipment has just a single primary winding, can I add another smaller 120v transformer in series to drop the input voltage and just leave the secondary open?
many thanks for your input
If I understand your intended connections, any transformer used would have to be the same Va.
Going to that extent, you might as well substitute the original with a transformer of the correct voltage.
M.
Sadly, no. That will drop the output volts too much, because the added primary isn't magnetically coupled to the existing primary. What you need (according to the Spice simulation attached) is an inductor (or transformer primary) with an inductance about 40% of the existing 120V transformer primary inductance and the same current-handling ability.
The above ideas work only for items with linear power supplies. OTOH, items with switching power supplies probably have universal inputs, but you won't know unless you check.
ak
ak
A SMPS supply will also work with a buck/boost transformer, in fact any lower higher voltage device.
But SMPS are usually various input voltages, the OP mentioned Linear supply.
But using the buck/boost principle is a little redundant.
Max.
Just use an auto transformer with the input connected across the entire winding and the output connected to a centre tap. Inductances is series with the input will give funny effects and will work properly on only one specific type of load.
Remember that a 60Hz transformer will have a harder life when running on 50Hz. If your load will stand it, it may be better to use a 100V input to the equipment.
