Charging super-capacitors in series?
hi,
i have a stack of six series super-capacitors (650 Farad each and 2.5V max).
I wish to charge them up with a 1 Amp charging current.
I wish to charge them up to 2.2V each (8.8V for the stack)
How do i ensure that during charging , and subsequent trickle-charging, no single capacitor suffers a voltage of greater than 2.5V?
I am thinking that there must be standard circuits for this?
davenn
hi there
try putting ... charging supercapacitors in series ... into google
there's a number of interesting articles that may help you on your way :)
Dave
An interesting question. I followed davenn's advice and found this. It's an interesting read.
ummm, did you intend a blank site ? :D
I found a quite useful 888kB PDF file there, both from work & at home. You draw a blank there?
I'd settle for using high power 2.4V zeners (or making them up from four 1N4001 diodes each), for the sake of simplicity, unless tested & proven to be inadequate.
Works fine for me. Maybe I can place it somewhere else for you...
here!
(Not taking the mickey)
davenn
here!
thanks mate, that one worked...
charging up lines of these caps isnt something I had really thought about. Obviously, others are as I see it a topic of interest across several electronic forums lately.
I mainly come across single ones in various gear I service that are purely supplying a small backup voltage for MPU's etc
cheers
Dave
