F
FlashGordonDownUnder
I want to be able to charge my 1.2V NiMH batteries while I am bushwalking.
Or more correctly I should say that I just want to be able to top up their
capacity while I'm walking as there will not be an oppotunity to be in the
one place for 10 (20?) hours with correct orientation to get the best
output.
My digital cammera and poratble HDD use 4 x 1.2V NiNH so I'd like to top up
the batteries as a group using a 12V 5W solar panel (Uni-solar flexible
type).
Could someone tell me if I can connect the panel directly to my batteries
(they will be in series = 5V) with a diode to stop reverse current back to
panel or should I be limiting the voltage with a zener or very basic
regulator to get the voltage capped at say 6 - 8 V. I'm not too worried
about the current as I'll never get more than about 230mA out of it and even
at this rate would be for a few hours maximum hence never reach capcaity of
batteries (which are 2300mAh).
As I'll be having a number of sets of batteries (4 per set) I could put two
sets in series and then charge that way but would my top up charging be
halved this way and become rather useless?
Thanks Gordom (from Downunder in sunny Sydney, Australia)
output.
type).
