Sir I need to charge a capacitor with three phase generator. Did three diode bridge but not charging. Any clue pls?
Thks
Thks
Draw out your circuit!
Hello,
Have a look at this page:
https://www.electronics-tutorials.ws/power/three-phase-rectification.html
Bertus
Thanks guys for response here is my circuit but capacitor not charging don't know why is this??!!!Draw out your circuit.
Disconnect the bridge,
Measure the resistance between the alternator outputs. Three readings.
Measure the output voltage between the three alternator outputs when running. Three readings.
Measure the resistance or voltage drop of each diode at both polarity. Twelve readings.
If one reading is different to the rest, disconnrct one end and measure it on its own.
Measure voltage drop across the bridge at each polarity. Two readings.
Depends how much generator is spinning but measured it all giving same voltage.Hello,
Can you measure the AC voltage between the phases?
Bertus
I am trying many but not one is holding charge. Is it maybe frequency problem??Hello,
What capacitor do you use?
You have given no information on that.
Bertus
No I tried with no loadHello,
You say you have tried several capacitors.
What where the values of them?
Is there a load accross the capacitor?
Depending on the load, the capacitor will be drained sooner or later.
Bertus
I used it on other capacitor without problem.Unless youu have a very sophisticated meter, it will discharge the capacitor. To get a significant discharge time you will need a large electrolytic capacitor and a meter with 10M input resistance.
What do you mean "not one is holding charge"?I am trying many but not one is holding charge
He'd depleted all his 'spent' up energy!The OP never returned to this thread.
Two years too late!
Martin
