Charge NiMH battery while still in circuit
I'm working on a senior project and i am looking for the best way to
charge a NiMH battery while it is still in use in the circuit.
Basically when the robot senses a low battery condition it hunts out a
docking station and docks. From there I'm a bit unsure on how to
supply the charge to the battery and when to stop. Any suggestions
would be great. Thanks.
Dean
martin griffith
On 21 Jun 2006 11:45:36 -0700, in sci.electronics.design
Dean
Look at the data sheet for the MAX712/3 charger. Basically the 712/3
has a low value current sense resistor feeding the battery, and it
depends on which side of this resistor you take your load from, as to
how the system measures the charge current.
FWIW several people have commented that the trickle charge is somewhat
high on this IC
martin
Nico Coesel
NiMh batteries are best charged by sensing their temperature while
charging. If the temperature rises more than 1 degree C, they are
fully charged. Panasonic had some nice documents on how to charge NiMh
cells.
NiMh cells may not be the best choice for your robot. They have a
nasty habit of dropping their output voltage very quickly when they
are empty.
Nico Coesel
cells.
Oops! Forgot something important. This should read:
charging. If the temperature rises more than 1 degree C PER MINUTE,
they are fully charged.
L
Luhan
Charging NiMH optimally can be very complex. I find it simpler to
simply charge to a 'cutoff voltage'. This gets about 80-90% charge.
http://members.cox.net/berniekm/unichg.html
Good luck,
Luhan
E
ehsjr
Dean
"Best" is undefined. "Best" can include consideration of
what charging power is available, physical size, cost etc.
In one scenario, you may need to charge very quickly, in
another the robot may not be used for a very long time, so
a trickle followed by a taper charge may be best.
For an unspecified "best" use a trickle/taper.
The "best" part of that is it won't cook your cells.
"First, do no damage."
Ed
