Changing photo resistor resistance range.
Chris W
I have a photo resistor that varies from about 400 ohms to about 15
million ohms in the desired light conditions. However I need something
that varies in resistance from 1k to 5k. Is there a way to do this with
a transistor? The circuit will always be supplied with a 100mV supply
which I suspect will effect the design of what I am trying to do.
Chris W
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
http://thewishzone.com
L
Larry Brasfield
Chris W said:
I have a photo resistor that varies from about 400 ohms to about 15 million ohms in the desired light conditions. However I need
something that varies in resistance from 1k to 5k. Is there a way to do this with a transistor? The circuit will always be
supplied with a 100mV supply which I suspect will effect the design of what I am trying to do.
What's wrong with the following?
o
.-----o-----.
| 6.2K | |
.-. '-'400 to >1M
| | | 620
'-----o-----'
o
John Fields
o
.-----o-----.
| 6.2K | |
.-. '-'400 to >1M
| | | 620
'-----o-----'
o
R1 = 6.2k
R2 = 400 -> 15M
R3 = 620
R1 (R2 + R3)
Rt = --------------
R1 + R2 + R3
6200 (400 + 620)
Rt1 = ------------------ = 875.9 ohms
6200 + 400 + 620
6200 (15e6 + 620)
Rt2 = ------------------- = 6197.4 ohms
6200 + 15e6 + 620
875.9 ohms to 6197.4 ohms isn't 1k to 5k.
John Larkin
R1 = 6.2k
R2 = 400 -> 15M
R3 = 620
R1 (R2 + R3)
Rt = --------------
R1 + R2 + R3
6200 (400 + 620)
6200 + 400 + 620
6200 (15e6 + 620)
6200 + 15e6 + 620
Note the op's use of the word "about."
John
John Fields
What makes you think I didn't?
I don't know about you, but for me, "about" is about 5 to 10% off of
nominal.
-12.4% on the low end and +23.9% on the high end is a little more than
that.
But thanks anyway...
Rich Grise
Well, what if you did a little algebra:
R1 (R2 + 400)
Rt1 = ----------------- = 1000
R1 + R2 + 400
R1 (R2 + 15e6)
Rt2 = ------------------ = 10000
R1 + R2 + 15e6
and solve for R1 and R2?
Cheers!
Rich
John Fields
R1 (R2 + 400)
R1 + R2 + 400
R1 (R2 + 15e6)
R1 + R2 + 15e6
John Fields
PS: If you're bitching about the ordering, go look up "associative
law".
E
Endoscope
John Fields said:
R1 = 6.2k
R2 = 400 -> 15M
R3 = 620
R1 (R2 + R3)
Rt = --------------
R1 + R2 + R3
6200 (400 + 620)
6200 + 400 + 620
6200 (15e6 + 620)
6200 + 15e6 + 620
To which Barry should reply.
Whoops! Sorry, Brane Fart...... Try 5K1 and 820R.....
Don't hold your breath though.
DNA
E
Endoscope
Endoscope said:
do
DNA
Oh ****, Barry might be Trolling/Teaching. His question was......
'What's wrong with the following?'
Oh shit..... I've just given him the opportunity to write 300 lines of
explanatory dribble.
Argggggghhhhhhhhh!!!!!!!!!!!!
Kill Me NOW.
DNA
L
Larry Brasfield
John Fields said:
R1 = 6.2k
R2 = 400 -> 15M
R3 = 620
R1 (R2 + R3)
Rt = --------------
R1 + R2 + R3
6200 (400 + 620)
6200 + 400 + 620
6200 (15e6 + 620)
6200 + 15e6 + 620
Despite occasional intimations to the contrary, I can
do arithmetic. What is not clear to me, and behind
my question to the OP, is whether your result (and
mine) is wrong for his purposes. I took the OP's
"1k to 5k" as a given to be achieved with what is
likely a cadmium sulphide cell illuminated with a
somewhat uncertain intensity, (hence the OP's
"about" qualifiers on its resistance range). Due to
more uncertainties stemming from the cell's TC and
its replacements, I elected to provide a range that
extended a little beyond what the OP stated. The
reason for more margin at the high end is that the
cell's high resistance extreme is likely to be more
uncertain than its low extreme. And if it is what
occurs due to night illumination, the moon might
cause considerably less than the stated MOhms.
Anther potential "wrong" aspect is that the mapping
from cell resistance to output resistance may not be
what the OP needs. Again, I rely on the OP to help
solve his own problem by stating such a deficiency.
Perhaps I should rephrase the question:
In what way will the OP's application misbehave if the
above circuit is used for the light-affected resistance?
Ban
But why did you choose non E12 or E24 values, I can understand when you go
off ideal values, and choose the closest standard ones, but you just write
non standard values just more than 20% off.
It might be in some old bin you found only those values, ok it will work,
but to deliberatly choose some random values is IMHO an unnecessary source
of error.
Or maybe it is that you are not familiar with standard E12? That would
qualify you as a bloody beginner.
L
Larry Brasfield
Ban said:
But why did you choose non E12 or E24 values, I can understand when you go off ideal values, and choose the closest standard
ones, but you just write non standard values just more than 20% off.
I suggest you study this table:
http://www.rohm.com/products/shortform/26rstr/rstr_index0.html
Then come back and explain your puzzlement.
It might be in some old bin you found only those values, ok it will work, but to deliberatly choose some random values is IMHO an
unnecessary source of error.
I deliberately chose 5% standard values to avoid
unnecessary confusion and low SNR posts here.
Or maybe it is that you are not familiar with standard E12? That would qualify you as a bloody beginner.
Please elaborate on this concept after your review
of the E24 table at the link I provided.
John Fields
I had no "result", other than pointing out that yours was quite a bit
away from what the OP asked for. Of course you could argue, ad
nauseam, that "about" means different things to different people and
put forth the conjecture that your results were "good enough", but who
cares?
G
Genome
cares?
Oh Shit.......
Leave it John.
Barry should have corrected himself properly.
Whoops!! 5K1 and 820R. Job done.
No not Barry.
And before he goes further I would just like to take this opportunity to
point out that his original answer did not include the 'caveats' he is now
giving and you are responding to.
DNA
L
Larry Brasfield
Your "properly" is a private concept.
No not Barry.
Your "Barry" shtick is silly.
My original question applies to your "perfect" values
as much as to the ones I posted. Going on and on
about "caveats" is pretty pointless when we have no
idea what the application requires.
I should point out that by misconstruing my added
'potential "wrong"' as a "caveat", you are missing
the point and making that obvious.
John Fields
Perhaps, since this _is_ seb, a more satisfactory approach would have
been to supply the OP with the tools which would have allowed him to
figure out his own solution(s)?
Y'know, "Build a man a fire and he'll be warm for a day, but set a man
on fire and he'll be warm for the rest of his life."
L
Larry Brasfield
[OT banter cut.]
That's a good point, on both the forum and approach.
For the simple resistance calculation, your depiction
of the arithmetic involved ought to suffice. Regarding
the problem of what exactness makes sense, that is
a much harder problem. I think some discussion of
the relevant issues, (preferably informed by some
knowledge of the application), is the best course.
G
Genome
John Larkin said:
Should we make an official verb out of that?
John
Hmmmmm, if I can remember it right.
I Barry
You Barry
We Barry
He Barries
She Barries
We Barry
They Barry
Looks good and regular to me.
I'll add,
Stop Barrying about.
Don't know the proper term for that one.....
DNA
