Ok I have this circuit diagram that I hooked up with 12 volt battery - 2 led's with dual terminals - low beam and high beam - high beam is 3.5 watt low beam is 1.2 watt - 1157 bayonet mount. I have 2 led flashers with battery terminal and load terminal I have a SPDT switch and a DPST switch
This circuit will be used to simulate a cars "front only" running lights, turn signal - left and right - and hazard lights.
I am uploading a pic of this circuit diagram. I have another circuit diagram that fixed my first diagrams problem almost 100 percent fix. Maybe someone could explain a total 100% fix
RUNNING LIGHTS "PARKING LIGHTS" ARE ALWAYS ON IN THIS CIRCUIT
PROBLEM WITH THE FIRST DIAGRAM:
Now, this first diagram has a problem. When the turn signal is turned on, either left or right, the high beam led is hardly noticeable, very dim, will not even pass inspection as a turn signal same with the hazard lights turn them on and they are very dim hardly noticeable
I am just uploading the diagram without the partial not 100% fix. Then I would like some feedback on what you think the fix would be to make the turn signals flash at full brightness.
WHAT IS THE FIX I AM LOOKING FOR?
When the turn signals or hazard lights are on they should bling at normal speed with full brightness
not dim or hardly noticeable
Thank you for your time
