centre tap rectifier
what are the advantages and disadvantage of centre tap full wave recifier.??
is it better than full wave bridge rectifier???
please explain in simple words.
Thanks...
At low voltages, the 1.2V or so drop in a bridge rectifier is significant so a centre tapped transformer winding is used with only two diodes. The voltage drop is reduced to 0.7V or so at the expense of a slightly bigger and more expensive transformer
At high voltages the diode voltage drop is not significant so a single cheaper winding is used with fatter, lower resitance wire.
Its all a matter of optimisation for the particular service.
