H
Harry Willis
As a CORGI registered installer, I have been podering upon the stated need
for cross bonding between the pipes connected to a newly installed gas
central heating boiler.
Assuming a typical UK domestic household, where the services are correctly
connected to earth as close to the entry point of the dwelling. I install a
new central heating boiler. With the make of boiler I install, the central
heating flow / return, hot / cold water and gas pipe are connected to metal
compression fittings that are in turn mechanically fastened to a metal
bracket that forms part of the boiler's casing.
It seems to me that this metal to metal contact between all of the pipes is
better and more robust than using earth bonds and a cable connecting them.
It is possible that the earth cable or bonds could become slack, or due to
the possibility of corrosion, become less effective. The metal bracket of
the boiler is a solid piece of equipment and to me, provides a more than
adequate cross bond between the connected pipes.
Comments?
Comments?
