Daniel Who Wants to Know
I recently lost 2 26W (100W equivelant) GE helical CFLs (FLE26HT3/2/SW) in 1
day due to having a 10,800 BTUH window air conditioner on the same circuit
causing low line voltage. Apon inspection it appears that in both bulbs the
same .1uF 250 VDC metal film capacitor (104J250) failed with it's guts
partially blown out and the end cracked loose. The main fusible resistors
in both bulbs are still good so I plan to replace the failed capacitor and
hope they start working again. I will let you know how it goes.
Word to the wise: The bulbs say 120V on them for a reason, if you plan to
use CFLs I would check your line voltage and make sure they are on a circuit
that doesn't experience many sags and surges (such as from... oh say maybe a
compressor cycling... DOH!!
BTW I love GE CFLs as I had 1 that lasted for 5 years 3 months and a week
and it was on 24/7/365 almost the entire time.
