G
GT
Hello,
I have installed Casi-Rusco Secure Perfect Micro5x panel and it is directly
connected to my pc. By mistake I have changed the setting for connection
type from "Direct" to "Dialup" in the software and once I clicked the "Save"
button the command was sent to the panel, and after that when I tried to
change back to "Direct" connection type I was keep getting "Micro not
connected" message. It seems like the panel is set for Dialup mode and now
I'm trying to connect as "Direct" via serial port. I tried to run the
"Flash.exe" utility to reset the Micro (Panel) and dump the firmware, but it
is of no use. The utility also shows the status as "No micro connected".
Could someone please tell me how to reset the Micro. It doesn't seems like
there is a reset button in micro itself.
GT
GT
