Hi All,
I am not in any way clued up with regards to this, but hope I can explain the issue a little bit...
I have a carpet cleaner / washer that works fine, except the brush won't turn. I have managed to identify (I think) that the main unit (which also detaches as a hand-held wet vacuum) also powers the brush by means of 'plugging into' the main unit when it is used within it, and this power is taken through the device to the bottom where (I think) the power is converted from 240v to 15.5v, which drives a motor, which in turn rotates the brush. I think there could be an issue with the 'transformer' or the circuitry between as I believe the motor to be OK. I have a couple of pictures of [possibly] the offending part, and also the model number etc. of the device (attached).
Any advice, help on parts etc would be good! I can't really afford a new cleaner unless I have to, plus I like this one!!
Many thanks
Many thanks
