So ive got a problem with my car battery going flat every now and then. Pretty standard, but it annoys me when i have to jumpstart my car. So my idea is that next time my car goes flat and wont crank over, i can flick a switch from the comfort of my seat then it will start. Effectively, flicking the switch gives me a jumpstart.
So to do this, i took apart a 17ah 20hr jumpstarter. With the case removed, the battery was a lot more compact. Then i wired it in parallel to my car battery. I took a shortcut or two, though, and wired the jumpstarter to the same wire as my 600w amp. Its earthed to one of the bolts that holds the drivers seat down. I left the switch that it came with in tact, since its designed to handle jumpstarter amperage.
It may be a problem, though, that im using the amp wire for both the amp and backup battery charging. The second battery will only charge when the switch is on. Now i must mention that im bypassing the fuse from the battery to the amp and jumpstarter. Im using copper wire in duct tape. I know, i should know better than that, but i have no spare fuse and wont get one soon.
after all the wiring, i did some voltage tests to check if it was all running sweet. Came up with these results and just wanted to know if from these results it seems like my setup works.
I took all readings from the main battery terminals. B1=car battery and B2=car battery and jumpstarter
first test
B1 = 12.64v-12.65v
flicking the switch
B2 = 12.65v to 12.66v
i gained .01v. Seems fine so far.
test while idling
B1 = 14.08v-14.09v
B2 = 14.07v-14.08v.
i lost .01v, probably because the backup battery was charging very slowly.
after a 1 minute charge.
B1 = 12.84v
B2 = 12.83v
Before charging i gained ~.02v after flicking the switch. After a short charge i lost ~.02v
It seems strange that the backup battery makes the voltage rise, but after a small charge it makes the voltage drop. I think i should test it again just to make sure but this could be a problem.
Im thinking that maybe the small voltage drop is because the main battery could be the jumpstarter when its connected. I wanted to confirm i havn't missed anything, and that these readings seem reasonable.
first test
B1 = 12.64v-12.65v
flicking the switch
test while idling
B1 = 14.08v-14.09v
B2 = 14.07v-14.08v.
B1 = 12.84v
B2 = 12.83v
