Hi I'm a student Electronics ICT and I have to explain the following circuit to my teacher.
I'm not sure what the function of these componnets are: R8, R9, R11, C5, C3.
Does anyone know? IC2a is an amplifier and IC2b, IC2c and IC2d are comperators.
Another circuit has an IR transmitter that will transmit against an object...it wil be received by D2--> that signal will be detected by D4, C4 (peakdetector)
the output voltage from the amplifier will be proportional to the distance from the object. The comperators will compare the constant voltage at the +input to the variable voltage at the -input...this will cause the right leds to light up at the right distance.
For example 3leds for 5cm and 0leds for 20cm
