john
I have a car battery charger with 3 settings: 2amp, 10 amp, and 50 amp
engine start. My issue is the 50 amp engine start mode.
When in this mode, the built-in ampmeter goes violently out of scale (full
scale is 12amp) before I even crank the engine.
This means the device has open circuit voltage of > 12V and is charging the
batter with more than 12 amps (not sure exactly how many amps).
I worry this large charging current may damage the car battery or cause an
explosion.
Wouldn't a better design be to provide 11.9V at 50Amps, so that when the
engine is not cranking, the battery will not be subject to a large charging
current, and when the engine is cranked, the battery voltage would drop a
few volts (due to enormous current draw), and the 11.9V at 50Amps will go
towards starting the engine.
Does anyone know if such charger exists?
explosion.
