Hello, I'm not sure if i should be posting this in a car forum, but since this forum deals with electronics and it's a battery question/capacitor i thought maybe i would try here
My car alarm is using taking too much power from my car battery(12V) Since it's a 2-way car alarm the amount of electric draw is normal. Usually, at 8pm the battery is at 12.66V, but when i test it in the morning the battery is at about 12.39V(which is enough to start the car. During summer i have no problem.
But when temperatures reach -20 to -30 in winter, and i test the battery in those super cold mornings the battery is at 12.16. Since it's very cold, usually the first crank won't start the car and by the second crank it usually starts, but if it is even colder, i might need a third crank and by then the battery is about 10V and no enough power to crank. If it's -30 or more, forget it. the battery is not at 100% so might as well not try it.
If i disconnect my battery overnight, and connect it back in the morning the car will start with no problem because the battery is at 100% so it has enough cranking power to start it at the first crank. Since my car is small i can't fit a bigger and more powerful battery in the car. So really i am out of luck. My only choice is to just get rid of the alarm system.
Anyways, Someone suggested a capacitor(might work) the ones they use in car audio systems. They explained to me it works but i have forgotten and i can't find anything reliable online.
How exactly does a car capacitor work. I know my car's alternator charges the 12V battery and then my car alarm system takes power from the 12V battery.
But with a capacitor, where exactly does it fit in.
As far as i know, the alternator charges both the 12V Battery & the Capacitor.
Afterwards, would the alarm system take power from the capacitor first, then after it is drained would move on to the 12 battery? But i'm doubting the capacitor would be fully drained by the time i wake up in the morning(8 hours later), and since the capacitor is not taking power from my battery, my battery would be at 100% every morning, then its sounds like a solution.
Is that how a capacitor works? Does it supply power directly to the car alarm, or
do capacitors charge the 12V battery when it starts to get low, I am guessing not because capacitors probably do not have enough power to charge a 12V battery, or do they?
I don't really understand what a capacitor is, Does anyone here know how capacitors work?
