I'm building a "battry zapper" for NiMH rechargable cells. Units that
do this are commercially available, however, all of them appear to
use military surplus parts (of which there are none right now) so you
can't buy one right now - I see no reason why someone with enough
sense to check and make sure they're doing it right couldn't build
one. I've also been given the name of a local EE, who appears to be
very difficult to get hold of...thank you for your help so far
everyone.
Quark - 125V caps (of lower capacitance?) wired in parallel? so if I
had 5 10,000uF caps rated at 125V I could wire them in parallel to
produce 50,000uF at 125V, and then only charge the caps to 100V? That
makes sense. I knew somewhere in my past I'd heard something funny
about charging caps wired in series or parallel, but I couldn't
remember exactly what it was. Thanks again.
Yes, wire five 10mF 125VDC caps in parallel is what you want. Make
sure that you don't charge them up to over 110VDC, or you'll risk
heating up the cap and making it explode.
And just to be a geek, let me explain why you don't want caps in
series.
Say you have a circuit
A B C
100V---(SWITCH)-----|C1|-----|C2|----|C3|----|> GND
Start with the switch open. Assume that all caps are discharged and
points A, B, and C are at the same potential as GND.
When you close the switch, point A will almost instantaneously reach
100V. The only thing charging capacitor C2 is the leakage current of
C1. The leakage current is probably VERY small. So the potential at
point B would be near zero for a while. And the potential at point C
is near zero too.
This means the voltage across C1 is about 100V! So if C1 is not rated
for 100V (let's say it's rated for 50V) then it will be over-charged.
This will cause the dielectric to breakdown and allow large leakage
currents. So you're essentially shorting 100V to point B (which is
about GND for the moment) through C1.
Bye bye C1!
-Quark
