sudden problem with Canon Copier PC720
clunky clangy loud nose, now paper does not go through it.
purchased new Fall 1997. Not used lot, just home copying when needed, and it has always worked perfectly with absolutely no problems.
Today, I copied something successfully, and was copying another page and red symbol indicating Paper Jam... I opened and added paper. Also opened main part and checked for any jams. Then I closed the lid and the red signal was OFF. The other lights were normal.
I thoroughly checked for any paper jam and there is none.
The red signal now went off.... I pushed to copy, and a big noise came on. I re-checked paper load, lessened it a bit... to no avail. Still a big clangy type noise.
Then I tried the manual feed with a piece of paper and noise just clangs. Powers on and off normal, other things are normal looking.
I love this copier, and hoping its an easy fix. I am hoping for suggestions of what is going on and if I could fix this. I have no mechanical abilities though. Thank you.
