Hi!
Is there any difference between the 2 following scenarios:
A: I charge a battery using a basic electronically controlled charger that will stop when it judges necessary.
B: I power the battery with a lab power supply to a voltage slightly above the battery voltage, and I stop once the current is getting close to zero.
And that leads us to a curiosity question: how does an electronically controlled charger work exactly?
Thank you!
Thank you!
