K
Klaus Kragelund
Hi
The schematic at:
www.microdesign.dk/tmp/dia.pdf
is a reference (TLV431) controlled by the Key signal that is present
in a car when the ignition is on.
Transistor Q5 if turned on will activate Q6 and turn on the reference
for the SMPS and get things running
The trick is that the Key signal is off when below 4V and on when
above 7V. But I have used a zener D30 and the BJT Q5 to set the
threshold level. This is not precise since this threshold will be
influenced by the current in Q5, the B+ voltage (between 9V and 32V),
the current in the zener and the temperature drift of these
components.
The temperature is from -40 to 125 degrees. Can anyone suggest a
better way to do this without using a dedicated opamp/comparator?
Klaus
The schematic at:
components.
Klaus
