Sir Sillencio / quiet . . . . . . . .
Referencing to your photo #1 . . .
You have two sets of two power transistors arranged across the top, being mounted to the heatsink.
There is an associated 0.22 ohm @ 5 W ceramic cased resistor below each power transistor.
Of those . . . . the 2nd resistor has seen extended heat strain.
That is thereby suggesting a severe or increased current drain being related to the second transistor.
Now . . . .are both of your audio channels working and if so is the power and quality of sound being the same ?
OR . . . is one channel being dead ? . . .or distorted ?
A start of analysis could be to take a DVM in DC mode and set at a very low range ( unless autoranging) , then power up the unit with no music input and measure across the 3rd resistors leads and log down. Then measure across the 4th resistors leads . . .log down.
Now aren't they being about the same ? . . . . . highly suspicioned . . . . . .
Then move to the 1st resistor and measure across it . . .log it down. Finally, measure across the 2nd resistor and that one should show a somewhat higher reading, than the others.
Also, can you confirm that all 4 transistors are being 2sC5198's.
Standing by . . . . . . .
73's de Edd . . . . .
Shin:
An anatomical part of the body, principally used for finding furniture in the dark.
