L
Larry Green
Hi Folks,
I have recently been asked to come up with circuit for a hobby project and
it has been many, many years since I last dabbled in electronics and circuit
design.
After a lot of thought and investigation on the web I think I now have a
feasible design but for some reason one side of my brain is telling me there
is an error while the other side is saying everything looks good!
The main area for concern is in the push button/de-bounce resistor
arrangement. I have a suspicion that they may need reversing (i.e. the
switch needs to be at the top and the resistor at the bottom). My 'logic'
tells me it is wrong at the moment and the inputs will be 'high' at all
times, however my rusty electronic theory brain cells tell me that due to
current flow the circuit is correct as it stands. I am also concerned about
the location of D2 which is acting as a reverse polarity protection device
in case someone tries to connect the 9V battery backwards with the switch
still in the 'on' position.
Can someone please check it over and tell me which is correct and if you see
any other glaring errors could you point me in the right direction on those
too. The circuit is designed to randomly select one of two sound options
after a random delay. One push button will start the random sequence while
the other two will each play one of the sound options for identification
purposes.
The circuit can be found here......
http://www3.sympatico.ca/larry.green/circuit_diagram.gif
Thanks for any help you can give, once I have the circuit nailed I can
concentrate on programming the PIC (a totally new area for me but I am on
the learning curve.....lol).
Larry Green VE3YET
design.
purposes.
Larry Green VE3YET
