Can I use a stock SIGNAL GENERATOR to drive an H bridge?
I
Ignoramus965
My objective is to make a square wave inverter for high amperage DC
for TIG welding, from a 300A CC DC welding power supply.
I would actually be content with 200A current. AC would be used for
aluminum only.
I own a Wavetek 171 signal generator:
http://www.labx.com/v2/spiderdealer2/vistaSearchDetails.cfm?LVid=2779965
It can do up to 10 volts, supposedly, and any frequency.
Can I simply use it to drive either MOSFETs or IGBT's that make up the
H bridge?
thanks
i
Pooh Bear
aluminum only.
H bridge?
Not directly.
You'll need some level translation.
If you don't know what that means then you shouldn't be attempting to make a
welder.
Unless you fancy welding *yourself* to something ? Terminally maybe ?
Btw - electronics hobbyists are advised to try out *low current* stuff
before progressing to the 'arcs and sparks' scenario !
Graham
I
Ignoramus965
Not directly.
do you refer to signal voltage level?
welder.
I would love to hear you share your knowledge.
i
Don Lancaster
Pooh said:
Ignoramus965 wrote:
Not directly.
welder.
Graham
There's quite a bit of gate capacitance in larger MOSFETS that has to be
quickly filled or emptied. Drivers are by no means trivial.
In fact, the design of the driver stage is usually much more difficult
than the output stage.
Many thanks,
Don Lancaster
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
voice: (928)428-4073 email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
I
Ignoramus965
Don, what are your thoughts on using IGBT's for switching?
i
Pooh Bear
i
Google IR2011.
That'll explain driving H bridges a bit. Be especially aware of the term 'high side drive'.
Graham
Pooh Bear
Graham replies that they're very good these days.
Mosfets are best at the higher frequencies though.
IGBTs have their own little 'quirks'.
trouble is.... you really have to have been doing this stuff for ages to pick up
the relevant issues. For a beginner, jumping in at the deep end involves a
cliff-like learning curve.
Graham
I
Ignoramus965
Google IR2011.
Thanks. I just read their spec sheet. Is there some other document
that you have in mind?
i
Jon Elson
Oh, boy! Now, you're REALLY getting in deep water!
The FETs are a lot more forgiving of shorts and linear operation, and
at the voltages you are looking at, they work a lot better, too.
But, still, you need perhaps 2-3 A of gate current for EACH FET in
your circuit! If you put 5 in parallel, you need 10-15 A of gate
current to charge the gates. Now, that is only for 50 nS or so,
then the current in the gate drops to zero. But, if you don't
provide this kind of current, the transistor will burn up in the
linear region before it ever gets fully turned on.
With IGBTs, if they are ever allowed to operate in the linear region,
even for a hundred nS, they are destroyed! The FETs have what is
called negative temperature coefficient, when they get hot, the
current they will conduct drops. This allows them to distribute
current evenly across the transistor, and across multiple transistors,
even when in the linear region. IGBTs flatten out in the saturation
region, but have a strong POSITIVE temp coeff. in the linear region.
Current will "hog" to the hottest part of the transistor die in the
linear region, and the transistor will self-destruct.
So, you really want to avoid the IGBT.
And, you will not be able to use your signal generator because it
can't provide several amps. You could do a low-power test, maybe
lighting an LED with it, to see the rise-times, etc. on your
scope.
For an H bridge, you need 4 different gate drives. Two of them
can be ground-referenced, but two of them (for the "high-side"
transistors) will have to be floating. You don't want to use
complementary transistors, ie. P channel, as they have MUCH lower
performance than N channel. So, using all N channel, the high side
transistors have their source connected to the floating output
terminal. So, the gate driver must supply gate voltage referenced
to the floating output voltage.
The IR 2113 and related chips can handle much of this stuff for
you.
One final problem is the DC welder will have a huge inductor at the
output. Thus, the output will probably have large voltage excursions
when the electrode touches the workpiece and the arc starts. So, you
can't depend on getting a steady 40 V DC or whatever. When the arc
breaks or sputters, you may have hundreds of Volts on the electrode
cable. I think the standard practice is to move the inductor to the
electrode cable AFTER the switching circuit. But, the design of
the welder may make this hard to do. Certainly in AC "buzz box"
welders, the output inductance is just built into the transformer,
it is not a separately-connected coil. I guess they can't do that
in a DC welder, so you may be able to change the connection there.
Jon
Pooh Bear
I can think of loads ! You can't imagine how many data sources I used before venturing into this
arena.
You need to examine the application notes really.
The ANs normally contain 'nuggets of wisdom' worth as much or more than gold.
Graham
Jon Elson
Yeah, like hanging on the cliff while the enemy is strafing you!
Actually, that is being showered by incandescent particles of your
expensive IGBTs, right after the cannon-like bang when they explode!
I know, I've been there. The last inverter design I worked on, I
had two glowing IGBTs shoot past my head on either side. After that,
I took to powering the thing up while crouching under the table with
ear protectors on. Once it survived power-up, I got up and looked at
the picture on the scope with a lot less fear.
I told all this stuff about keeping out of the linear region, etc.
to a guy working on a hybrid electric car drive, but he had to do
it his way! He ended up with a Ford Taurus wagon filled with batteries
almost doing a wheelie inside a garage full of people when the IGBT
popped!
Jon
I
Ignoramus965
My frequencies will be low, think 50-300 Hz or so.
ages to pick up the relevant issues. For a beginner, jumping in at
the deep end involves a cliff-like learning curve.
I am hoping that I can get some help from learned and esteemed experts
here... Doubtless, I could not undertake this project alone. I hope
that there will be people who may take enough interest to stop me if I
do something stupid. I am not really afraid of, say, losing $80 that I
would spend on components that blow up, although I would prefer not to
endanger anyone's safety.
I already did many interesting things by "standing on the shoulders of
giants", such as repair of a diesel generator or building of a phase
converter etc. I am saying this not to brag -- these were relatively
simple things compared to electronic design issues that some of you
are experts in -- but rather to underscore that projects can be brought
to successful completion with a bit of care, open mind and good advice.
i
Spehro Pefhany
Google IR2011.
Graham
Better read the application notes really carefully too. What you don't
know will fry expensive semiconductors, typically a few at a time.
Best regards,
Spehro Pefhany
I
Ignoramus965
arena.
Thanks. I will read them closely tomorrow, when I print that document
out.
That said, can I get some intro on how these chips are used? Are they
connected to DC power (for sending signals to MOSFETs), as well as to
a signal generator that "drives" the chip? How do I tell the chip what
to do?
Is that big enough for a 12 kW power transmission device, or is it
just an example?
I apologize if this question is answered in application notes.
i
Pooh Bear
Best regards,
Spehro Pefhany
Trouble is....
Even when you do know it, you're likely to fry several by accident for good measure anyway !
Fzzztttzzzzzzttt ! poPPPP ! BANG !!
Graham ;-)
I
Ignoramus965
Got it.
That's not good...
Okay.
scope.
you.
Very nice. I will try to read the PDF file about it to see if I can
make sense out of it and understand how it should be wired.
got it.
Thanks.
i
I
Ignoramus965
popped!
I once tried to start a diesel generator (Onan DJE,
http://igor.chudov.com/tmp/onan/Diesel/), sitting on a firnuture
moving pad.
A surprise for me was that when it started, it jumped off the pad.
Fortunately, I forgot to disconnect chain hoist from it and it saved
the generator as it kept it in an upright position.
i
Pooh Bear
out.
to do?
just an example?
So many issues !
When you've read a few ANs about gate drivers pop back in and ask again.
Ohh - and you do know about how to control circulating currents in pcbs ?
Graham
I
Ignoramus965
So many issues !
Thanks. I will spend quite a while reading that stuff. That said, all
I find are spec sheets. Is there some secret location for application
notes, say for the IR 2113 driver?
i
