I am beginning to study JFETs . I want to limit this discussion to N
channel JFETs and when I talk about current flow I mean conventional
current flow.
Most of the sources that I have been studying use example where the
gate-source junction is reversed biased and the voltage at the drain
is positive with respect to the source and current flows from drain to
source.
What if the gate-source junction is still reversed biased and the
voltage at the drain is negative with respect to the source. Will
current now flow from the source to the drain?
I have also read somewhere that on "some" JFETs, the source and drain
connections are interchangeable while on others they are not. Is this
true? If so, how do you know which ones will do this?
Any help would be greatly appreciated. Thanks
current flow.
source.
