i went to an electronics store today looking for high voltage
capacitors for building a marx generator,the lady behind the counter
was as confused as i am by the name spark gap capacitor. can anyone
tell me how these are any different if at all from regular capacitors,
and would they work for a marx generator?
No difference in function, but maybe a difference in construction - A
cap specifically intended for spark-gap use might be built a bit
"beefier" to avoid frying it with the high voltages that a spark gap
wants to run at, or with different materials so that its "dump" speed is
faster, but aside from that... <shrug> A cap is a cap is a cap, at least
as far as basic function is concerned.
Basically, it sounds like you're looking for a high voltage rating, high
capacitance unit. What voltage range are you expecting the spark gap to
fire at? Use that as a base, and look for something rated for at least
that high a voltage, if not higher, in the mFd/pFd range your tuning
calls for. Your main worry is probably going to be arcing between the
plates and the possible resulting "pop" (or maybe "KABOOM!", depending
on how much power you're running) that can result from exceeding the
breakdown voltage of the cap's dielectric material.
