can anyone suggest a low voltage plug solution for our sculpture project?
I am trying to find some sort of plug solution for our low voltage sculpture projects. each sculpture has a red and black wire, to match the 12volt power source
we want to be able to plug each one in when we set them up, rather than wire them altogether
bullet connectors and disconnects always yank the wire right out of the crimp because they are so hard to pull back apart
we want about 100, so we are hoping for something under .25 each
we were using rca jack plugs, which in one way worked great, the bad thing is how they put the hot wire wrapped inside the grounding wire. its a pain to separate the wires
can't believe no one else wants some sort of small low voltage plugs
just two wire
without soldering
thinking of trying tamiya
any suggestions?
davenn
Anderson connectors from powerx are ideal DC power connectors for your situation
and at an affordable price in bulk
cheers
Dave
