Basically tell me about difeerent regions
Platforms
Content
As you pull current through the emitter - base the resistance between the emitter and collector changes.
Gain = collector current divided by base current.
A BJT is a transconductance (voltage controls current) device. In the active region, the base current is an indicator of the collector current, but does not control it. The base current is an unavoidable waste that does not contribute to transistor operation.
Ratch
And there is nothing incorrect about that explanation at all. I find the current story easier to demonstrate, changing current to show gain. You can't explain gain by discussing base voltage.
You cannot show current gain without driving the base with a current source, or adding a lot of resistance to the base and/or emitter. From then on, you are demonstrating a current amplifying circuit using a transconductance device, not a BJT alone. A BJT by itself is not an inherent current amplifier.
Ratch
What you see on a data sheet is a test circuit using the device. The test circuit contains current sources. I never said that a BJT should be designed as a voltage driven device. It is too nonlinear for that. However, it is not a current amplifier by itself like a lot of books and magazines say it is.Your description of the transistor is correct. What formula for gain do you use that uses base voltage? when I read a datasheet for transistors it references collector current and base current to describe gain. We can't use base voltage to indicate gain because the same base voltage gives different gain at different collector currents.
Is there a graph of base voltage versus collector current on a data sheet for a 2N3904?
You are correct about how the transistor works but nobody uses this description on a data sheet ... unless you can show one. It is technically true, but can't be applied.
Ratch
You speak as though it must be one or the other. Both approaches are acceptable.
I am not clear on what you mean by "one or the other" and what the approaches are.
Ratch
Yes, we can look at the transistor from the standpoint of a base voltage controlling the collector current or we can view it as base current controlling collector current. Most data sheets refer to base current. It takes an engineer's view to understand it is base voltage.
For me, I can't calculate gain using base voltage. My input signal is base current. I am unconcerned with base voltage. Base voltage just falls where it may.
On an LED, I control current. Voltage across the LED falls where it may.
you have to add lots of resistance to overcome the nonlinearity
the opposite to way most do it
you have a LED of say 2.5V and 25mA, you want to run it off 12V, you choose a resistor that will drop the other 9.5V across it when 25mA is flowing
The voltage across the LED cannot be random or arbitrary as you suggest it must be correct cuz if you have a higher V then more current will flow
and it will have a short and brilliant life
??? Elaborate on this, please. At what point does the nonlinearity change? Yes, it is nonlinear. The linearity changes based on current. The voltage is incidental. The voltage is the result of the current. The causal force at work is the current. Nowhere in the data sheet does it relate base voltage to collector voltage or current. The correlation is incidental.
Explain how you imagine base voltage is significant?
From outside then transistor I change resistance to change the current. I need not consider base voltage.
Inside the transistor operation is describe in terms of current carriers, not voltages.
Do you have another description?
Yes, in a specific circuit we can relate base voltage to collector current but the observation cannot be applied to a different circuit. There is no correlation between a specific base voltage and some collector voltage or current.
By making the emitter resistor high enough, most of the base volt will drop across the emitter resistor and determine the collector current. The more most of the voltage is dropped across the emitter resistor, the more linearly the transistor will amplifier the current.
Ratch
