I have a newly acquired Lincoln Engine Driven Welder. The Vantage 300 is a great machine and this one is runs excellent. It has a diesel Kubota powering a 12.5kw generator that powers a 300 amp welder.
The generator operates as it should. I checked all the wiring, voltage, current, etc.... and it's spot on. The welder is another issue...... the chopper had been found to be bad and was removed. I acquired it less the chopper and a new chopper hovers around $2,000. This welders NEW counterpart is $2500 and is a better welder.
As it is.... I am happy to have it as a portable generator. But I would LOVE to have the welder back in action.
Can a chopper be built? Can the chopper be circumvented? You get the gist. All the other items are still with the welder. The inverter, control panel, choke, etc.... The research I have done at Lincoln Electric states the chopper was a 20,000hz unit. A potentiometer feeds its current to the chopper telling the chopper to feed the welding circuit the desired juice.
What can be done?????????????
Pete
Pete
