I have Camera DataSheet , Not Again !?
Pin# Pin name Description I/O State @ State @ State@
1 AF_GND
2 GND Ground - - - -
3 VDD_AF Voltage supply for autofocus (2.7 V)
4 SCL I2C serial bus clock I/O HiZ HiZ Active
5 GND Ground - - - -
6 SDA I2C serial bus data I/O HiZ HiZ Active
7 VDD_SA Voltage supply for analog part of sensor (2.7 V)
8 VSYNC Vertical synchronization signal O Low HiZ HiZ
9 GND Ground - - - -
10 HSYNC Horizontal synchronization signal O Low HiZ HiZ
11 VDD_IO Voltage supply for DSP I/O (2.7V)
12 XRST System reset I - - -
13 TRIG Interrupt signal O Low HiZ* HiZ*
14 CAPTSTRB Capture/strobe signal O Low HiZ* HiZ*
15 GND Ground - - - -
16 D[6] Digital video data O Low HiZ HiZ
17 D[7] Digital video data (MSB) O Low HiZ HiZ
18 D[4] Digital video data O Low HiZ HiZ
19 D[5] Digital video data O Low HiZ HiZ
20 D[2] Digital video data O Low HiZ HiZ
21 D[3] Digital video data O Low HiZ HiZ
22 D[0] Digital video data (LSB) O Low HiZ HiZ
23 D[1] Digital video data O Low HiZ HiZ
24 GND Ground - - - -
25 VDD_SD Voltage supply for digital part of sensor (1.8 V)
26 MCK System clock input I - - -
27 DCK Digital video data clock O Low HiZ HiZ
28 GND Ground - - - -
29 GND Ground - - - -
30 VDD_L Voltage supply for DSP core (1.2 V)
