I was reading the article "Introduction to GSM and GSM mobile RF transceiver derivation" by Paul Kimuli [http://www.rfdh.com/ez/system/db/li..._and_GSM_mobile_RF_transceiver_derivation.pdf].
On page 2 (page 16 within the article) under the heading "Phase Error and frequency error", he says: "To measure phase and frequency error, test sets can be used to sample transmitted output of the devices under test to capture the actual phase trajectory. This is then demodulated and the ideal phase trajectory is derived mathematically."
I'm wondering why would you calculate the ideal phase trajectory from the demodulated transmitted output. Shouldn't the ideal phase trajectory be calculated from the raw data bits being fed into the transceiver? Because what if the transceiver's transmitted output is completely off. Then the demodulated signal will be completely off. Then the calculated "ideal" phase trajectory will be completely off. Then the comparison between the ideal phase trajectory and the actual phase trajectory would be invalid since the calculated ideal phase trajectory is wrong in itself.
Thank you!
Thank you!
