hey all, i have been working on this problem for days now...and it should not be this hard but i can not get it to work.
I need to design a simple circuit so that when a thermistor is heated with a lighter, its resistance drops and creates a bias voltage of at least .7V volts through an npn transistor, and then this transistor lights an LED.
Could someone please explain this circuit, how it works, and perhaps even draw a simple schematic? I can only thank you so so much.
I can't even get the right resistor value, but here are the values you have
Resistance of thermistor when at room temperature: 4500ohms,
Resistance of thermistor when heated up: 3500 ohms.
Resistance of collector: 1000 ohms
VCC: 5 volts
I need to find R2, please help lead me through a voltage divider calculation and please help me draw out the schematic. I've spent way too much time on this
VCC: 5 volts
