CharlesBlackstone
I hope to run a 40' pair of cables from my power supply (Mastech
3010E-3) to my charger (Thunder Power 1010C). Here's what I've been
thinking, I could use any thoughts you might have on the right way to
go about this. The Mastech push 60v/10a or 30v/20a and the TP 1010c
can charge at 10 amps (with 12 volts input I presume and will need 10
amps in).
I've been googling and found these cable gauge calculators, which tell
me I need 10 or 12 gauge to carry 20 amps for 40 feet, which doesn't
seem like much. But, most of them are calculating AC voltage I presume
since they specify 120, 220, etc volts.
http://www.gorhamschaffler.com/wire...calculator.html
http://www.freesunpower.com/wire_calc.php
http://www.elec-toolbox.com/calculators/voltdrop.htm
If I am pushing 60v and 10 amps, or 30v and 20 amps, is 10 gauge wire
safe? I was thinking about overkill for peace of mind and using 2
gauge; Autozone sells 2 gauge 20 foot jumper cables for $42. The TP
1010c can charge at 10 amps, and I presume at 12v. If I try charging
batteries, and the cabling stays cool, should I feel safe? I'm not
conversant with electrical stuff and nervous. The cable will run from
my office to the patio outside, through my house. If I can't feel safe
I'm going to move the Mastech next to the patio, but have reasons why
I don't want to do that.
Thanks.
Jim
cloud-9 is online now Send a private message to cloud-9 Find More
Posts by cloud-9 Edit/Delete Message
amps in).
Thanks.
Jim
