Mike H
I have an IC (LM334z) with 3 pins. +V, -V, and Rset. This IC is designed
to output a fixed current based on Rset regardless of input voltage.
The spec sheet says that the total current through IC is the sum of the
current going through the SET resistor and the bias current for the IC.
The formula is presented as Iset = Ir + Ibias = Vr/Rset+Ibias
The data sheet for this IC can be found here:
http://www.national.com/pf/LM/LM334.html
The question is, for a input voltage of 12 - 14 volts DC, what set
resistor should be used to reach 20mA of current?
What would the formula look like using those voltages but wanting to vary
the output current?
I guess I'm just a bit confused on how to calculate it and what all values
I need to take into account when I do so.
Any help is appreciated. Thanks.
the output current?
