Glenn said:
If I have an empty bobbin 20mm ID and 100mm long, using 28 AWG enamel
wire, how can I calculate how many turns to achieve a reistance of 12
Ohms?
Resistance is 0.076 Ohms per foot, but I am not clear about the math
formulae.
I wrote some software a while back that estimated the number of turns
(or length of wire) providing you knew other critical bits.
The basic requirement was you needed to know what diameter wire it was,
and the physical dimensions of the bobbin, including the diameter of the
core of the bobbin.
The software made the assumption you could neatly roll a layer of wire
to fit the width of the bobbin, calculate that, then do it again on the
second layer, which was now assumed to sit on top of the first layer.
Repeat layers till you get to the outer diameter, or whatever will fit
on the bobbin.
Even with the assumptions, it was close enough to be usable.
I used it mainly to determine how many *turns* I could get onto a
bobbin using a particular wire type. Great when I needed a certain
turns ratio, but had no idea determining the amount of wire the bobbin
can hold.
Unfortunately, this was back in the DOS days, I've lost it since then,
and I've moved into IT so I don't need to re-write it. So can't help.
It's certainly not hard though, nothing that early basic high school
maths can't sort out.
Even if you have to factor in resistance.
