George Herold wrote...
Interesting, Thanks Phil. Say I noticed the other day that the opa134
has current noise that starts to rise dramatically with frequency
above 2kHz or so.
http://focus.ti.com/lit/ds/symlink/opa134.pdf
See the graph at the bottom of page 4.
Is this common for all jfet opamps? I've never seen other spec
sheets that plot current noise vs. frequency for FET opamps.
The current noise is so low, 3fA/rt-Hz, that it's scarcely
significant. But it's still interesting to analyze.
Often this type of very low spectral-density noise, rising
proportional to frequency, is due to a capacitively-coupled
signal from a spectrally-flat voltage-noise source.
We can calculate, i_n = e_n 2pi f Cx. For example, assume
the JFETs have 60k drain resistors, which gives about 10nV
of Johnson noise. If this is coupled to the input via some
capacitance, etc., we can calculate, Cx = I_n / 2pi f e_n.
For noise at some frequency on the plot, we get Cx = 0.06pF.
Is that due to Cdg, or is it some other small capacitance?
If the opamp had a cascode input stage for the JFETs, their
drains should not be exposed to high voltage noise. It's
possible the opa134 doesn't have a cascode input. TI says,
"The p-channel JFETs in the FET input stage exhibit a varying
input capacitance with applied common-mode input voltage."
