I've inherited a TV with good picture and sound, but absolutely atrocious sound. I want to hook up some old PC speakers up, while retaining the ability to change the volume with the remote.
The TV has an aux input but it's not very good. It has a separate volume setting in a menu somewhere and sound still comes out the internal speakers.
I want to bypass the internal speakers completely to a female aux input which I can plug my PC speakers/headphones into.
Figured it would be pretty easy to bodge something together.
This is what I found inside:
Seems very simple, each speaker (ringed) receives 2 wires from the board, just like 2 phono cables.
I only unplugged the white (left) and red (right) wire from the speaker, the black cables are firmly clamped on.
I wired a female RCA/phono wire to each of the speaker wires, which I connected to my headphones, but the audio was drowned in hiss on both sides.
However, if I just wire the left or right individually, I hear it perfectly clear and crisply through my headphones, it's only when I have both that I get tons of hiss.
And if I connect both female phono wires to one side then I also get a perfectly crisp sound (albeit mono).
Can someone explain what's going on and how do I fix it for perfect stereo?
