Buzzing Makita DC1414 F charger
I have the above Makita charger which is buzzing with a variable frequency when the green LED flashes.
I have tried prodding the transformer and various components but the buzzing doesn't stop.
I don't want to start replacing capacitors on the chance that may cure the buzzing.
Attached are photos and a video showing the buzzing can be downloaded from this link:
https://ufile.io/v78dr3o2
Any suggestions on where I should start looking?
Thanks.
Hi CirKit,
The free (slow) D/L doesn’t work.
Can you describe the buzz?.
Is it only when the LED flashes?.
Is it definitely a buzz rather than a high pitch tone?
Martin
Download worked for me.
It is a medium to high pitched sound (similar to an electric razor, but not so loud). The frequency changes with the blinking of the LED: LED on -> frequency high, LED off, frequency low. Notable peaks are around 4 kHz and 6 kHz:
It sounds like the caps aren’t doing their job. Given the stresses these caps go through in SMPS, they are also the first components to fail.
I would replace them as a matter of course.
Martin
bertus
Hello,
When you change the fourrier size and look at the spectrum, the 100 Hz is good visible:
You will also see signals at 4000, 8000 and 12000 Hz.
Bertus
