Buying Advice Please: Toshiba CF3072B
Darren Harris
I have the opportunity to purchase a Toshiba CF3072B TV for $225 from
a repair guy a couple of blocks from me. When I saw the set turned on
in the shop, it seemed to have a good picture, but at the very top
there was a very thin horizontal line of random color. It probably
wouldn't be noticeable under normal circumstances, but it was there
nevertheless.
Can anyone tell me if this is indicative of a major problem in the
TV's immediate future, or does it sound like a simple fix?(The repair
guy said that he could fix it before sale).
More importantly, is it even worth it to buy the set at that
price?(Especially since it has a 30 inch tube).
Any advice would be appreciated.
Thanks a lot.
Darren Harris
Staten Island, New York.
Jerry G.
The set is starting to have a vertical deflection fault. This can be most
likely aged capacitors. If the service man was to take the time and expense
to fix it properly, he will make less on the resale. I am sure he figures
that the set is working good enough for now, and in about a year or so the
buyer will be back for a nice repair job.
Greetings,
Jerry Greenberg GLG Technologies GLG
WebPage http://www.zoom-one.com
Electronics http://www.zoom-one.com/electron.htm
nevertheless.
Thanks a lot.
Darren Harris
David
Old, old, old.
Has signs of an impending vertical failure from failing capacitors due to
its old age.
Check the back of it, probably an early 1990's model.
I would run, not walk. I find it hard to believe a reputable repair shop
would try and sell a set that clearly has a problem. Especially for $225
for a 10+ year old 30" set.....
techforce
What Kind of Warranty comes with it if any?
Above Average Shops Will give a Nice Warranty not only on repair jobs, but
2nd hand stuff too.
But for NYC area, I have my doubts.
Alan Harriman
Old, old, old.
its old age.
That would be a 1992 model. Side firing speakers, single tuner PIP,
one RF and two video inputs including s-video, and variable audio
output jacks. In its day, a pretty decent set. I would value the set
at $100 to $125, if it's in excellent condition, is guaranteed, was
used in a non smoking environment, and includes the original remote.
If you consider its purchase, make sure the vertical is repaired,
which will probably require several capacitors. He should also check
the caps in the power supply, and elsewhere as needed. A careful
visual inspection of pcb board should be performed to check for loose
and intermittent solder connections and repaired as needed.
Check to make sure the pix is not stretched or compressed, ie short
legs and/or long heads. To get some indication of the picture tube's
condition, ask to see a black and white channel. Make sure the pix is
truly B&W. Next, run the contrast up and down and make sure the colors
don't bleed at high brightness and contrast levels. If it fails either
test, the tube is probably going bad.
Alan Harriman
Darren Harris
Thanks a lot.
I guess I'll have to look elsewhere.
Darren Harris
