Hello all! Thank you for accepting me. I am looking to pick you more advanced builders brains for a second, if you dont mind. I dabble in just about everything. My stoves blower quit working, on the "high" setting. Stove isnt very old. Pulled the panel today. Just as suspected, the board is burnt under the relay. You can still hear the relay click when you push the button for the high setting. But the fan doesnt work. I flipped the wires around on the relays, since there is one for low and one for high. The fan seemed to pull harder when the wires were switched. Not sure I understand how the fan works. It is my understanding that if the fan is 120v, then its 120v on either setting. That would leave me to believe that the motor is wound different in each setting. Therefore if it works when I switch the wires, on the high setting, then there is no issue with the motor itself. If the relay still clicks and shows no sign of damage, should I be ok just repairing the burnt spot on the board? The copper path burnt away, but the board underneath is fine. Normally I would replace the relay as well, but I am having a hard time finding a replacement. Although, it seems something had to be at fault for the burnt board. Fluke??? Poor removal of flux before assembly? I will say there is some grease (food) that has leaked onto the connector at the other end of the harness. Possible it allowed something to short? FIgured that would show sign at the plug... TIA
Platforms
Content
